Recommended limit in a cluster of AP105s
  • 1.  Recommended limit in a cluster of AP105s
    Posted Apr 24, 2013 08:08 PM
    Is there a recommended limit in a cluster of AP 105s? i know the limit is unlimited but is there a recommended number like try not doing clusters of more than 200 APS for example...
    I got  a project in which we are quoting around 115 IAPs  105s
    They do not have the budget for the controller so well  we thinking in going with this...
    But still i would like to know if there is any kind of recommendation on the size of a single cluster of AP 105s
    Cheers
    Carlos
    #AP115
  • 2.  RE: Recommended limit in a cluster of AP105s
    Posted Apr 24, 2013 09:17 PM
    Marcus Answered me this one
    Its 65 and it apply to all instants models.
    Cheers
    Carlos
  • 3.  RE: Recommended limit in a cluster of AP105s
    Posted Apr 25, 2013 01:53 AM
    Hello Carlos.
    Remmber that there is limit to 1024 devices connected to one InstantAP cluster too.
    Regards
    Jaroslav
  • 4.  RE: Recommended limit in a cluster of AP105s
    Posted Apr 25, 2013 01:57 AM
    Yes i already knowthat...
    the scenario here is an hotel with 140 rooms.
    like 2 conference rooms of 250  max in each...  so i really doubt that igoes over 1024
  • 5.  RE: Recommended limit in a cluster of AP105s
    Posted Apr 26, 2013 09:41 AM
    With the addition of L3 mobility in IAP code, the cluster size is less of a concern now. Specificy your home and foreign agents and roam away. QA/Engineering is pushing the limits on 'supported' cluster sizes in the coming releases.
    Adam
  • 6.  RE: Recommended limit in a cluster of AP105s
    Posted Apr 26, 2013 09:56 AM
    Thanks for the info Marcus also told me that.
    For now im including him  airwaves for centralized managment.   As it will have many clusters...
