Wired Intelligent Edge
Recommended setup of a VSF link
  • 1.  Recommended setup of a VSF link
    Posted Dec 02, 2019 12:31 PM
    Hi, I'm a little confused about the optimal configuration for my particular case.
    I have two Aruba 2930F and suppose I want to make a VSF between them with two physical ports for redundancy. Currently I have it configured like this:
    vsf
       enable domain 9000
       member 1
          type "JL259A" mac-address 9cdc71-37da40
          priority 255
          link 1 1/23
          link 1 name "I-Link1_1"
          link 2 1/24
          link 2 name "I-Link1_2"
          exit
       member 2
          type "JL259A" mac-address 9cdc71-362fe0
          priority 128
          link 1 2/23
          link 1 name "I-Link2_1"
          link 2 2/24
          link 2 name "I-Link2_2"
          exit
       port-speed 1g
       exit
    Reading the documentation I think I understand that it would be best if I had 1 VSF link of two ports, this way:
    vsf
       enable domain 9001
       member 1
          type "JL259A" mac-address 08f1ea-4a4020
          priority 255
          link 1 1/23-1/24
          exit
       member 2
          type "JL259A" mac-address 548028-6068e0
          priority 128
          link 1 2/23-2/24
          exit
       port-speed 1g
       exit
    If this last configuration is the best, could I make the configuration change in such a way that it doesn't affect the network traffic too much?
    If so, how should I proceed in this case?
    Thank you in advance for your assistance.
    Best regards
    Gabriel
  • 2.  RE: Recommended setup of a VSF link
    MVP GURU
    Posted Dec 02, 2019 11:25 PM
    The second is better (the first solution will don't work with only two if you look vsf status / topology)
    Yes, you can make change (Need to remove the port for link 2 and add to link 1)
