You can use the next link: https://networkingsupport.hpe.com/
You need an account to login and you can download the desired firmware in the next part:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/f97f3741bd2f41f48bd18008cf028297.png)
In the section of Endo of Life, you can check de latest soported versions LSR y SSR:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/aed238b3e2ab4f9f954b1b706a3847c5.png)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/0175009bcc0e44f89ecbfdb62d41ea09.png)
I hope this helps
FC
Original Message:
Sent: Jul 26, 2024 10:12 AM
Subject: Recommended version for AP-505 firmware
any idea where to locate latest Long Supported Release 8.10.x ?
Original Message:
Sent: Mar 26, 2023 06:10 PM
Going with Long Supported Release (LSR), it will be 8.10.x
but if you are looking for specific new feature then go with the latest version and check release notes.
Original Message:
Sent: Mar 26, 2023 06:48 AM
Please need to know the recommended version for AP-505, also how to know the current version.
Appreciate your support
