On your Aruba controller, navigate to Configuration/Authentication/L3 Authentication/Captive Portal Authentication. Click the entry you're using with ClearPass, then 3 lines down into the config there's a value titled "Redirect Pause". I set ours to '1' which seems to be working quite well.
