last person joined: 9 hours ago
Redirect to Captive Portal using HTTPS
  • 1.  Redirect to Captive Portal using HTTPS
    Posted Nov 20, 2015 12:21 AM
    When I connected to the Captive Portal SSID on ArubaOS
    and I used http://xxx.com it's works fine
    but when I used https://xxx.com it return the web page that I must accept the certificate and sometimes it show nothing to accept the certificate.
    Can I solve this problem?
  • 2.  RE: Redirect to Captive Portal using HTTPS
    Posted Nov 20, 2015 05:25 AM
    Try with a different browser... can you post a screenshot?
  • 3.  RE: Redirect to Captive Portal using HTTPS
    Posted Nov 20, 2015 05:46 AM
    Yes, I have added the attachment files.
  • 4.  RE: Redirect to Captive Portal using HTTPS
    Posted Nov 20, 2015 07:33 AM
    TCK2534,
    This is a common problem.  If you redirect a user from an https page, they will always get the certificate error, because that is not the page they requested.  This is in industry problem with Captive Portal.  Please see here:  http://serverfault.com/questions/596844/ssl-certificate-errors-in-captive-portals
    The user will always have to be redirected an http page for this to work smoothly.
