Redundancy between 2 sites
  • 1.  Redundancy between 2 sites
    Posted Aug 14, 2013 03:47 AM
    I'm still a novice w/ Aruba products so I might need a little help / guidance:
    Currently we have 20 APs at the "main site" and we have one 3200XM-controller. We just decided to expand our current WLAN to a remote site that would also need about 20 APs to get covered.
    Is there anyway to get the benefits of redundancy w/o upgrading the current 3200 to 3400 and buying another 3400 to the remote site?
    #3200
    #3400
  • 2.  RE: Redundancy between 2 sites
    Posted Aug 14, 2013 07:35 AM
    Since the total of 40 APs you have mentioned will exceed the capability of the 3200XM (32 APs), you have to get creative if you don't want to upgrade that to a 3400.  Also, you'll need to license the redundant controller fully to support failover, unless you are running 6.3 and centralized licensing.
    If you don't want to upgrade the existing 3200XM, you can setup AP Groups to prioritize which APs will failover to the 3200XM should there be a failover from the remote site; in this case up to 12.    So you'd have three AP Groups with AP System Profiles to reflect the following:
    1) Set with 3200XM as primary and 3400 as backup
    2) Set with 3400 as primary and 3200XM as backup (up to 12 APs in this configuration)
    3) Set with 3400 as primary (and no backup)
