It could be a crazy idea, but i know everything is possible with Aruba!
I'm testing new design of a local controller in branch office that is connected via IPSec tunnel to master controller.
is there a possibility to create a failover or redundancy between 2 Controller ports when one port is connected to MPLS circuit and the other port is connected to broadband (2 different vindors), so if the MPLS circuit goes down for any reason, the office will stay up using the broadband connection?
In another words:
Port 1 connected to MPLS circuit and active
Port 2 connected to broadband and standby
If port 1 disconnected, port 2 will keep the office working, and when port 1 back to work, port 2 will hand the traffic back?
hope i describe my question well!
Thank you,
