Redundancy Configuration
  • 1.  Redundancy Configuration
    Posted Jul 21, 2016 11:52 AM
    Hi ..
    I'm trying to configure Redundancy for Vlan between 2 local controllers ,,, and I set one of them high priority (200) and other controller (150) ,, but all of them become master when I apply it !!?? so access points are divided to 2 local controllers !! as it shown in attached scaeen shots
    How can I solve that plz ?
  • 2.  RE: Redundancy Configuration
    Posted Jul 21, 2016 12:00 PM
    You should:
    - Uncheck Preemption from both sides
    - Set a password on both sides to make sure they are only communicating with each other.
  • 3.  RE: Redundancy Configuration
    You should:
  • 4.  RE: Redundancy Configuration
    Posted Jul 21, 2016 01:02 PM
    I do that .. NO change ! stil both sides are master !
  • 5.  RE: Redundancy Configuration
    Posted Jul 21, 2016 01:03 PM
    Can both sides ping each other?  Is there anything that would be blocking the VRRP advertisements?  Can you make sure that portfast is enabled on your uplink switch on those ports?
  • 6.  RE: Redundancy Configuration
    Posted Jul 21, 2016 01:14 PM
    Yes, each sides can ping other
    uplink ports to both sides are enabled
    but, when i press (apply) it shown me this message (attached screen shot)
  • 7.  RE: Redundancy Configuration
    Posted Jul 24, 2016 07:26 AM
    Helloooo ..
  • 8.  RE: Redundancy Configuration
    Posted Jul 24, 2016 10:25 AM
    You should open a TAC case so that they can take a look at your logs.tar.  I am not sure your problem is simple enough to be answered on this forum.
