Wired Intelligent Edge
last person joined: 7 hours ago
REDUNDANT PORT
  • 1.  REDUNDANT PORT
    Posted Aug 30, 2017 10:33 PM
    WHAT IS THE REQUIREMENT FOR THIS FOR THE ARUBA SWITCH TO MAKE IT USABLE ON THE SERVER SIDEWHAT IS THE REQUIREMENT FOR THIS FOR THE ARUBA SWITCH TO MAKE IT USABLE ON THE SERVER SIDE
    provided the server was configured NIC Teaming, if i plug directly without tweaking the Aruba Switch 3810M switch can it automatically fuction as redundant setup?
  • 2.  RE: REDUNDANT PORT
    Posted Sep 03, 2017 09:12 PM
    do i need to enable LACP o configue it? i need help on this please
  • 3.  RE: REDUNDANT PORT
    Posted Sep 05, 2017 03:26 AM
    Hi gascon,
    This all depends on what the other device supports. But probably LACP passive will be the best option.
    It would be nice if you let me know if all information on the other thread helped setting up the infrastructure.
    Regards, Dobias
  • 4.  RE: REDUNDANT PORT
    Posted Sep 05, 2017 11:40 PM
    hi,
    thanks for replying, so i just enable the LACP, what do you mean passive? or can you show me the configuration how to do LACP PASSIVE? thank you!
  • 5.  RE: REDUNDANT PORT
    Posted Sep 06, 2017 03:21 AM
    This is correct. You can enable LACP passive with the following command:
    trunk <por list> lacp
    Off course you need to configure the other device also as static LACP. In the ArubaOS Switch management configuration guide chapter 7 port trunking, there is a lot of information on these protocols. Hereby the link:
    http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=a00021320en_us
