Reference spectrograms for healthy networks
  • 1.  Reference spectrograms for healthy networks
    Posted Mar 28, 2013 02:51 PM
    Is there any place that has a library of healthy spectrograms and fft's, particularly for high density deployments?
    I'm wondering because in the attached image, channel 11 had a pretty solid red line where no other channels have that problem, and I suspect it's causing some interference issues.
    Any suggestions?
  • 2.  RE: Reference spectrograms for healthy networks
    Posted Apr 02, 2013 03:15 AM
    There is Aruba document ( I think whitepaper) for this but I can't find it right now.
    You can also google out this document, it's slightly more desriptive: "airmagnet spectrum xt user guide pdf"
  • 3.  RE: Reference spectrograms for healthy networks
    Posted Apr 02, 2013 08:06 AM
    May I ask, is this a problem that you are dealing with?  The spectrogram tells a certain part of the story, but by itself it does not mean the network is "bad".
  • 4.  RE: Reference spectrograms for healthy networks
    Posted Apr 02, 2013 11:49 AM
    We were having an issue with bandwidth availability and packet loss in that section of the building, particularly in that classroom. It was likely an overload issue and has since been resolved (upgraded from single radio to dual radio with N), but it still appears there is some interference in channel 11 on the 2.4 ghz band (hence the red line). I'd like to get it cleaned up, if possible, but I want to make sure that it actually is interference.
    In the originally attached image, there is a pretty solid red line in the center of channel 11 that does not appear in other channels, so I was wondering if it was normal to appear that way or was it something worth investigating as possible interference. That's why I wanted to see a healthy spectrogram, for comparison.
  • 5.  RE: Reference spectrograms for healthy networks
    Posted Apr 02, 2013 11:51 AM
    Agreed.
    With your spectrum analysis tool, does it indicate what devices are on channel 11 that are wifi, vs. non wifi?  You have to identify what is causing it to possibly do something about it...
  • 6.  RE: Reference spectrograms for healthy networks
    Posted Apr 02, 2013 12:01 PM
    It's the built-in spec analyzer on the aruba controller (running latest 6.2) with an ap135 scheduled in spectrum mode, in case you were wondering... great tool.
    It lists a freq-hopper (cordless base) in the channel, but there isn't anything like anywhere in the viscinity of the ap, so I don't know... we'll keep looking.
  • 7.  RE: Reference spectrograms for healthy networks
    Posted Apr 02, 2013 12:29 PM
    Okay,
    Spectrum provides part of the picture, but that might not be the sole issue affecting your network.
    What is your primary issue?  Are your clients using encryption?  When did it start happening?
