refreshing AP-204 with AP-304
  • 1.  refreshing AP-204 with AP-304
    Posted Jul 16, 2018 10:17 AM
    we are running some AP-204 with sector antennas. Now we have to add AP-304. How can you run 2 antennas on AP-304? Can you disable the 3rd antenna port or do we need to install rp-sma "0-6 GHz RP-SMA plug terminator"
  • 2.  RE: refreshing AP-204 with AP-304
    Posted Jul 24, 2018 02:00 PM
    Yes, to use a 2x2 antenna on a 3x3 AP, you would need to install an rp-sma terminator on the unused antenna connector on the AP-303.
