Regarding SNMP query on monAPInfoCurrentChannel
  • 1.  Regarding SNMP query on monAPInfoCurrentChannel
    Posted Aug 17, 2015 09:16 AM
    Outputs from a SNMP query on monAPInfoCurrentChannel (1.3.6.1.4.1.14823.2.2.1.6.7.1.1.1.2) for the SAME ap with different clients. Why does the channel change? How to interpret this channel number?
    Thank you!
    SNMPv2-SMI::enterprises.14823.2.2.1.6.7.1.1.1.2.ap.2.client = Gauge32: 4
    SNMPv2-SMI::enterprises.14823.2.2.1.6.7.1.1.1.2.ap.2.client = Gauge32: 1
    SNMPv2-SMI::enterprises.14823.2.2.1.6.7.1.1.1.2.ap.2.client = Gauge32: 6
    SNMPv2-SMI::enterprises.14823.2.2.1.6.7.1.1.1.2.ap.2.client = Gauge32: 11
    SNMPv2-SMI::enterprises.14823.2.2.1.6.7.1.1.1.2.ap.2.client= Gauge32: 1
  • 2.  RE: Regarding SNMP query on monAPInfoCurrentChannel
    Posted Aug 17, 2015 11:16 AM
    from MIB
      monAPInfoCurrentChannel OBJECT-TYPE
             SYNTAX       Unsigned32
             MAX-ACCESS   read-only
             STATUS       current
             DESCRIPTION
                "      Channel the monitored AP is using.            "
    so it's the channel of the AP that is seen. i.e. it's analgous to the column "chan" in the output of "show ap monitor ap-list ap-name <>"
    Example:
    root@bt:/home/aruba/mibs/6.4.2.8# snmpwalk -v2c -c whatever -M. -mALL -O0X 192.168.1.164 monAPInfoCurrentChannel
    <snip>
    WLSX-MON-MIB::monAPInfoCurrentChannel[STRING: ac:a3:1e:c3:7d:f2][1][STRING: 18:64:72:93:67:f0] = Gauge32: 60
    WLSX-MON-MIB::monAPInfoCurrentChannel[STRING: ac:a3:1e:c3:7d:f2][1][STRING: 18:64:72:93:67:f1] = Gauge32: 60
    WLSX-MON-MIB::monAPInfoCurrentChannel[STRING: ac:a3:1e:c3:7d:f2][1][STRING: 48:f8:b3:b8:20:78] = Gauge32: 36
    WLSX-MON-MIB::monAPInfoCurrentChannel[STRING: ac:a3:1e:c3:7d:f2][1][STRING: ac:a3:1e:b7:df:30] = Gauge32: 36
    WLSX-MON-MIB::monAPInfoCurrentChannel[STRING: ac:a3:1e:c3:7d:f2][1][STRING: ac:a3:1e:b7:df:31] = Gauge32: 36
    WLSX-MON-MIB::monAPInfoCurrentChannel[STRING: ac:a3:1e:c3:7d:f2][1][STRING: ac:a3:1e:b7:df:32] = Gauge32: 36
    WLSX-MON-MIB::monAPInfoCurrentChannel[STRING: ac:a3:1e:c3:7d:f2][1][STRING: c4:a8:1d:78:20:ac] = Gauge32: 40
    WLSX-MON-MIB::monAPInfoCurrentChannel[STRING: ac:a3:1e:c3:7d:f2][1][STRING: e0:3f:49:59:f1:8c] = Gauge32: 157
    WLSX-MON-MIB::monAPInfoCurrentChannel[STRING: ac:a3:1e:c3:7d:f2][1][STRING: e8:de:27:74:43:a2] = Gauge32: 44
    <snip>
    some ap mac ac:a3:1e:c3:7d:f2 sees a bunch of APs, they are all on different channels of course. The actual channel of the monitoring AP is not really important - but it is very very likely there will be way more APs visible on the home channel due to higher dwell time on that channel.
    example, lets just look at radio[1] (11a) for this AP ..... 7d:f2
    (sg-7030) #show ap database long | include ac:a3:1e:c3:7d:f2
    ap205              lab                      205      192.168.1.23  Up 8d:1h:48m:33s  2      192.168.1.165  0.0.0.0     ac:a3:1e:c3:7d:f2  CM0126348  N/A   N/A   N/A
    (sg-7030) #show ap active | include ap205
    ap205           lab      192.168.1.23  0            AP:HT:11/6/20        1            AP:VHT:36+/9/23      205      2da    8d:1h:48m:36s  N/A
    (sg-7030) #show ap monitor ap-list ap-name ap205 phy-type a
    Monitored AP Table
    bssid              essid             chan  ap-type      phy-type       dos      dt/mt          ut/it  encr            nstas  avg-snr  curr-snr  avg-rssi  curr-rssi  wmacs  ibss
    ac:a3:1e:b7:df:30  v1-7030-psk       36    valid        80211a-VHT-40  disable  693732/693732  0/0    wpa2-psk-aes    1      0        0         0         0          13     no
    ac:a3:1e:b7:df:31  v1-7030-cp        36    valid        80211a-VHT-40  disable  693732/693732  0/0    wpa2-psk-aes    0      0        0         0         0          0      no
    ac:a3:1e:b7:df:32  dot1x-vlan        36    valid        80211a-VHT-40  disable  693732/693732  0/0    wpa2-8021x-aes  0      0        0         0         0          0      no
    18:64:72:93:67:f0  iap-v1-psk        60    valid        80211a-HT-40   disable  121431/2797    4/0    wpa2-psk-aes    2      29       29        65        66         2      no
    e8:de:27:74:43:a2  dlink-media-1D66  44    interfering  80211a-VHT-80  disable  16923/16923    15/14  wpa-psk-tkip    0      9        10        86        85         1      no
    e0:3f:49:59:f1:8c  ASUS_5G           157   interfering  80211a-HT-40   disable  13831/251      23/0   wpa2-psk-aes    0      8        8         86        87         0      no
    48:f8:b3:b8:20:78  PandaMANGIS       36    interfering  80211a-VHT-80  disable  13201/13201    49/48  wpa2-psk-aes    0      6        7         89        88         2      no
    18:64:72:93:67:f1  iap-cp            60    valid        80211a-HT-40   disable  4821/94        4/0    wpa2-psk-aes    0      29       29        66        66         0      no
    Length:8
    Total:8
    hth
    -jeff
  • 3.  RE: Regarding SNMP query on monAPInfoCurrentChannel
    Posted Aug 17, 2015 11:32 AM
    So those channel numbers actually reflect a fact that the AP has been scanning and *meeting* other APs/stations at different channels?
    Also your replies help me understand a lot, as well as brings a lot of new surfing and reading for me. Anyway, they are really helpful. Thank you.
  • 4.  RE: Regarding SNMP query on monAPInfoCurrentChannel
    Posted Aug 17, 2015 11:46 AM
    Just for clarity, when I write (and our docs say) that the AP scans, it means that it moves off channel and dwells for some period of time and passively listens. The dwell time is not configuration (it used to be) and is generally assumed to be around 80ms, such that the AP can return the it's home channel before the next beacon needs to be sent. This takes place nominally once per 10 seconds (refer ARM profile scan time setting).
    some caveats...
    >> There is a notion of agressive scanning too - that just means that if the AP is idle it can go off channel before the 10 second expiry.
    >> There are some cases where scanning is deferred, due to various checks such as VOIP call active, load etc, this is called "scan reject".
    >> some channels are scanned more frequently than others, there is a notion of 'rare channels' and 'inbetween channels' etc that are scanned less frequently than say the main blocks of unii-1,2,2e,3, this is achieved using a weighting scheme:
    (sg-7030) #show rf am-scan-profile default
    AM Scanning profile "default"
    Parameter                                   Value
    Scan Mode                                   all-reg-domain
    Dwell time: Active channels                 500
    Dwell time: Regulatory Domain channels      250
    Dwell time: non-Regulatory Domain channels  200
    Dwell time: Rare channels                   100
    you can view the AP scanning behaviours using the command "show ap arm scan-times ap-name <>" -- the output is reasonably self explanatory; but if you have questions post back here.
    no problem at all, glad to hear it's useful info.
    regards
    -jeff
