Regarding to Instant OS
  • 1.  Regarding to Instant OS
    Posted Jun 27, 2019 06:17 AM
    I'm new to Aruba, currently planning wireless network for 3 floor hotel.
    Will use approx. 22 APs.
    Have several questions;
    1. What is the maximum APs that can be controlled with InstantOS virual controller?
    2. Can I mix AP models for one cluster, for example AP-303 and AP-365?
    Thanks in advance.
  • 2.  RE: Regarding to Instant OS
    MVP EXPERT
    Posted Jun 27, 2019 06:20 AM
    You can easily manage 22x AP in a single InstantOS cluster. You can also mix-match AP models in the same cluster. The APs will just need to all run the same firmware version. Aruba recommends a max of 128 IAP in a cluster however there is no hard limit.
  • 3.  RE: Regarding to Instant OS
    Posted Jun 27, 2019 06:26 AM
    Thanks Craig!
