Regulatory domain of IAP
  • 1.  Regulatory domain of IAP
    Posted Mar 06, 2013 10:09 AM
    How to change the regulatory domain of IAP
  • 2.  RE: Regulatory domain of IAP
    Posted Mar 06, 2013 10:21 AM
    There are 4 regulatory domains for IAPs:
    -US (United States)
    -JP (Japan)
    -IL (Israel)
    and one with no designation. Ex. IAP-105 (Rest of World).
    These designations are hard-coded and cannot be changed.
    Care must be taken when ordering to be sure the correct IAP model is ordered based on where it will physically be deployed.
  • 3.  RE: Regulatory domain of IAP
    Posted Mar 06, 2013 10:33 AM
    Thank you Marcus,
    How can i verify the regulatory domain of running IAP?
  • 4.  RE: Regulatory domain of IAP
    Posted Mar 06, 2013 10:36 AM
    check the web interface, Country code at the screen in the left bottom should tell you. changing probably means reseting the AP, but as mentioned you can't switch between certain domains based on the hardware.
  • 5.  RE: Regulatory domain of IAP
    Posted Mar 06, 2013 10:45 AM
    Got that.. that is what i was looking for...
    Thank you so much
  • 6.  RE: Regulatory domain of IAP
    Posted Mar 06, 2013 10:40 AM
    There is a sticker on the back of the AP that shows the model and country code.  Ex IAP-105-US.  If the APs are already ceiling mounted you can also go into the WebUI > Maintenance > Configuration.  The third line down shows the country code.  Ex.  'virtual-controller-country US'
  • 7.  RE: Regulatory domain of IAP
    By the way.. in Rest of World we have many options available. i just want to confirm which option has been configured in my running IAP.
