regulatory domains
  • 1.  regulatory domains
    Posted Apr 22, 2014 05:58 AM
    Hi friends!
    I have applied regulatory domains (as I understood that each country has a slightly different local regulation on RF spectrum)
    Trouble is when I apply the RD, the AP thinks there are no usuable channels and enters AM mode.
    ": No valid channels; entering air monitor mode."
    I guess there is a global setting on the controller that needs to match the AP's RD setting but cannot find it  - anyone had this?
    thanks
  • 2.  RE: regulatory domains
    Posted Apr 22, 2014 06:30 AM
    What the full type/model of your AP ?
    • U should fit your contoller R.Domain to your AP R.Domain. Check if your AP got any country code at the end - and ajust your R.Domain.
    • wrong R.Domain will make your AP work only as AM.(Also be sure to use AOS that supporting this AP on the R.Domain u would like to work)
  • 3.  RE: regulatory domains
    Posted Apr 22, 2014 06:31 AM
    AP-225
  • 4.  RE: regulatory domains
    Posted Apr 22, 2014 06:32 AM
    OK
    just AP-225 or is it AP-225-XX ?
    what is the AOS you using on your controller?
  • 5.  RE: regulatory domains
    Posted Apr 22, 2014 06:33 AM
    And,To what R.Domain u would like to change it?
  • 6.  RE: regulatory domains
    Posted Apr 22, 2014 06:35 AM
    yep - just a AP-225
  • 7.  RE: regulatory domains
    Posted Apr 22, 2014 06:36 AM
    AoS 6.3.1.5
    I think I see what you are driving at here
  • 8.  RE: regulatory domains
    Posted Apr 22, 2014 06:38 AM
    what domain?
  • 9.  RE: regulatory domains
    Posted Apr 22, 2014 06:42 AM
    all over eatern europe and russia
    example Kazakhstan
  • 10.  RE: regulatory domains
    Posted Apr 22, 2014 06:46 AM
    You should choose R.Domain that allowing the usage of your AP-225..
    (Read 6.3.15 Table24 Release notes)
  • 11.  RE: regulatory domains
    Posted Apr 22, 2014 09:22 AM
    Just put something like Canana or or something near your country(which is on the list that got 225)  and it will work.  Your conuntry is not added to the regional domain yet so it will go to air monitor.
    Check this webpage
    https://pctools.arubanetworks.com/compliance/
    It will tell you which country are added.  or you could read the release notes like kdisc98 told you as well.
    Cheers
    Carlos
  • 12.  RE: regulatory domains
    Posted Apr 22, 2014 09:55 AM
    Hi nightsade - that is right on the money thanks.
