Rejoining Access Points from AOS 6.5 to AOS 8.7
This thread has been viewed 35 times
  • 1.  Rejoining Access Points from AOS 6.5 to AOS 8.7
    Posted 14 days ago
    I will install new Aruba 7010 controllers with AOS 8.7 soon. This will replace an AOS 6.5 environment. Once I have installed the new 7010's I want to reprovision the Aruba 305 Access Points that previously were joined on the AOS 6.5 controllers. What is the best way to do this ?
    1. Reprovision the AP's from AOS 6.5 by providing the new controller addresses and reload the AP's ?
    2. Configure the new controller address on option 43 of the Access Point scope / Vlan and reload the AP's ? ( not sure if that is enough)
    3. Configure the new controller address on option 43 of the Access Point scope / Vlan and factory default the AP's with the "paperclip procedure" (not sure if it is required)
    4. Something else ... ?
    Thanks in advance :-)
  • 2.  RE: Rejoining Access Points from AOS 6.5 to AOS 8.7
    Posted 14 days ago
    #2.  Just make sure that the ap-groups that exist in ArubaOS 6.5 also exist in 8.x​
  • 3.  RE: Rejoining Access Points from AOS 6.5 to AOS 8.7
    Posted 8 days ago
    Will the 305 AP's need a factory default reset of will reprovisioning from AOS 6 with the AOS 8 controller IP address be enough ?
  • 4.  RE: Rejoining Access Points from AOS 6.5 to AOS 8.7
    Posted 8 days ago
    You do not need to factory default the 305s.  The ip address would be enough.
  • 5.  RE: Rejoining Access Points from AOS 6.5 to AOS 8.7
    Posted 6 days ago
    We have just migrated today and it went fine. Created the AP group form AOS6 and reprovisioned the APs. Thanks very much for your input ! .
  • 6.  RE: Rejoining Access Points from AOS 6.5 to AOS 8.7
    Posted 12 days ago
    1.Reprovision the AP's from AOS 6.5 by providing the new controller addresses and reload the AP's.
    I have done this before, it works.
    just make sure ap provisioning to new controller IP (don't provision wrong address, or that will make a big work to do.)
