Release 4.0.0.7 aP 103
  • 1.  Release 4.0.0.7 aP 103
    Posted Jul 10, 2014 10:41 AM
    Hello i would like to know which firmware you use to apply to the Instant 103?
    As you see in the picture the 103 is not listed...
    Do you put it the same firmare of the AP 115???
    Cheers
    Carlos
  • 2.  RE: Release 4.0.0.7 aP 103
    Posted Jul 10, 2014 11:06 AM
    ~~Edit~~
    I just noticed that you are looking at v.4.0.0.7..........
    The IAP-103 requires v.4.1. which is why you do not see it listed in v.4.0.  It is listed in the v.4.1 release.
