Hello:
I am brand new to Aruba. I am testing some Aruba equipments right now. The AP that is local to my controller (7005) are working fine. The problem I have is with the 225AP at a remote location. Here is the basic setup
225 --SW--- PA(Firewall) ------IPSEC -------PA(Firewall) -------Controller 7005---DNS Server
From the remote network, I can ping aruba-master and resolve via nslookup. Once the AP got the DHCP address, I can ping the AP from the controller and the controller from the AP. But the AP will never assocaite with the controller.
I have try to console into the AP, it will sit at the Master: screen, then reboot. I did try to hardcode the controller IP, once I did that. The AP will show up inside the controller with the I,D Flag but I cannot do anything to it. I try to change the profile, but the AP never restart.
I did a capture on both end of the firewall, some UDP aruba-papi traffic got drop. I suspect MTU between the tunnel was the problem. I drop the MTU to 1400 but no luck.
I did plug the AP at the local network at first and all work fine, but once I relocate them. It stop working...
Have anyone run into a similar problem? Any suggestion would be appreciated.
Gary
#AP225
