Remote AP console config
  • 1.  Remote AP console config
    Posted Mar 05, 2012 04:45 PM
    I was wondering if its possible to totally config a AP for example a 105 AP im not talking about the rap 2wg....
    Okay if i provision it on site and then come with my AP to the remote site okay it works fine...
    But what happens if i don twant to locally provision it... let say i want to configure a AP 105 totally from factory default to connect as a remote ap to the controller?
    this is the config i was putting on it
    setenv ipaddr 192.168.3.171
    setenv subnetmask 255.255.255.0
    setenv gatewayip 192.168.3.254
    setenv serverip 200.75.219.13
    setenv master 200.75.219.13
    save
    reset
    And its doing this
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    eth0 up: 100 Mb/s full duplex
    DHCP broadcast 1
    *** Unhandled DHCP Option in OFFER/ACK: 28
    DHCP IP address: 192.168.3.122
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 192.168.3.254
    DHCP DNS server: 192.168.3.254
    DHCP DNS domain:
    Using eth0 device
    TFTP from server 200.75.219.13; our IP address is 192.168.3.122; sending through gateway 192.168.3.254
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: T T T T T T T T T T
    Retry count exceeded; starting again
    DHCP broadcast 1
    DHCP DNS domain:
    Using eth0 device
    If you see its putting another IP not the one i put it through the cli console... and its stuck doing that...
    What im doing wrong?
    i also tried doing
    setenv remote_ap=1
    Im still in the same thing...
    Any help?
  • 2.  RE: Remote AP console config
    Posted Mar 05, 2012 05:33 PM
    New AP’s which are shipped do not have any image on the flash. Hence you see the “Invalid image” error. The AP will try to contact the controller and get its image and then should work fine post that. If you are provisioning over a WAN link, there is a chance that tftp may be blocked or dropped in the path. You can try provisioning the AP to a controller on the same network or you can put the AP image on a tftp server and have the serverip provisioned on the AP to be this tftp server IP. To provision this as a remote AP, you need to set the parameter setenv remote_ap = 1 in the apboot.
  • 3.  RE: Remote AP console config
    Posted Mar 05, 2012 06:04 PM
    hello
    Yeah it was something really silly... just had to port forward or in this case as i was too lazy i just put that ip on the dmz on my linksys router... im testing at home that stuff..
    anyways everything works fine exept that it wont pick the ip im telling ....
    it keep getting ip from the DHCP server...
    it times out in getting a dhpc address..
    If i put the dhcp server again it works...
    as you see i treid configuring the static ip address
    with
    ap> setenv ipaddr < IP Address for the AP>
    ap> setenv subnetmask <subnetmask>
    ap> setenv gatewayip <gateway ip>
  • 4.  RE: Remote AP console config
    Posted Mar 05, 2012 06:09 PM
    It is netmask
    Below is how you set it:
    setenv ipaddr x.x.x.x
    setenv netmask x.x.x.x
    setenv gatewayip x.x.x.x
  • 5.  RE: Remote AP console config
    Posted Mar 05, 2012 06:21 PM
    Yeah i just figured that out by provisioning the remote ap
    then  going to the ap boot and then doing print i saw the netmask...
    Ill look for the tread here i saw someone telling it was subnetmask i copied that form someone here telling that mmm
    or is it an old command???
    and now is changed to netmask?
    http://community.arubanetworks.com/t5/Access-Points-and-Mesh-Routers/Faulty-AP-105-not-attaching-to-controller/td-p/21100/page/2
    thats the tread...
    anyways ill post there also... someone might also see it and will have the same trouble i had...
    Anyways thanks man! Kudos! :)  everything is cool now
  • 6.  RE: Remote AP console config
    MVP
    Posted Mar 06, 2012 03:49 AM
    I've attached a very old doc whioch lists the AP commands possible.
    Note that some 'aliases' have been made ('purgeenv' for example can now be entered simply as 'purge')
    Attachment(s)
    pdf
    AP Commands.pdf   413 KB 1 version
  • 7.  RE: Remote AP console config
    Posted May 09, 2012 11:52 AM
    Please try without the equal sign. thats the correct command
    apboot> setenv remote_ap 1
    apboot> save
    Saving Environment to Flash...
    Un-Protected 1 sectors
    .done
    Erased 1 sectors
    Writing
    apboot>
  • 8.  RE: Remote AP console config
    Posted Aug 13, 2015 07:39 AM
    Green power LED bulb blinking continuously.
    Item reset several times , but system not initialized, problem still there
    Here is my configuration  i was putting on it
    setenv ipaddr 192.168.3.9
    setenv subnetmask 255.255.252.0
    save
    reset
    And its doing this
     Hit <Enter> to stop autoboot:  0
    @Checking image @ 0xf6100000
    @Checking image @ 0xf6800000
    Invalid image format version: 0xc
    eth0: down
    eth1: up, 1 Gb/s, full duplex
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    save
    reset
    And its doing this
    @Checking image @ 0xbf100000
    @Checking image @ 0xbf800000
    DHCP broadcast 1
    DHCP DNS domain:
    Using eth0 device
    DHCP broadcast 1
    DHCP DNS domain:
    Using eth0 device
    i also tried doing
    setenv remote_ap=1
    Any help?
    kindly help us to solve this issue
  • 9.  RE: Remote AP console config
    Posted Aug 13, 2015 07:41 AM
    You did not set the "dnsip" variable, so your AP cannot find "aruba-master", because it does not have a dns server configured.
  • 10.  RE: Remote AP console config
    Posted Aug 13, 2015 08:07 AM
    how to configer dnsip please help me...
  • 11.  RE: Remote AP console config
    Posted Aug 13, 2015 09:16 AM
    What are you trying to do?  The way you have it configured is not the way things are typically done.  It is harder this way.
  • 12.  RE: Remote AP console config
    Posted Aug 21, 2015 01:05 AM
    hi all,
    please help me to solve this problem...
    My boss purchased 3 items on Aruba AP-135 with out controller...
    i am new to aruba product, no idea about compatible controllers for aruba ap 135,
    1.Aruba 2400/2400E 24-Port Access Multiplexer Wireless LAN Mobility Controller
    2.Aruba 650-US WLAN Mobility Controller
    3.ARUBA NETWORKS 3400-US WIRELESS LAN 4-PORT MULTI-SERVICE MOBILITY CONTROLLER
    4.Aruba Networks 800 8-Port LAN Mobility Controller
    which products support aruba ap 135 please comment here
  • 13.  RE: Remote AP console config
    Posted Aug 21, 2015 01:08 AM
    The 650 and 3400 will support the AP-135 but those controllers are very old
    and one is EOS.
    You should consider a 7005 contorller.
  • 14.  RE: Remote AP console config
    Posted Aug 21, 2015 01:15 AM
    what about the license it should be annually renew or will comes with life time warranty
  • 15.  RE: Remote AP console config
    Posted Aug 21, 2015 01:17 AM
    You will need at minimum AP licenses.
  • 16.  RE: Remote AP console config
    Posted Aug 13, 2015 07:42 AM
    save
    reset
    And its doing this
    eth0: down
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
