Remote AP migration from 6.5 to 8.4
  • 1.  Remote AP migration from 6.5 to 8.4
    Posted May 15, 2019 02:52 AM
    I had to migrate an AOS6.5 environment to AOS8.4. The environment contains multiple campus APs and remote APs. To ease the migration I exported and imported the whitelist-db from 6.5 to 8.4. This works perfect for the campus APs, but not for the remote APs.
    The Cluster-InnerIP value isn't populated when importing the whitelist-db. I had to add all the entries manually. You can read more about the problem in my blog post:
    Migrate RAP from AOS 6.x to AOS 8.x
    Does anyone know if there is another way to "import" the whitelist for remote APs?
  • 2.  RE: Remote AP migration from 6.5 to 8.4
    Posted Jan 21, 2020 08:12 AM
    Hi René. Did you get any news on this?
    I'm going to do a upgrade from 6.5 to 8.6 and I would like to know if I will have to manually entries like you did.
  • 3.  RE: Remote AP migration from 6.5 to 8.4
    Posted Jan 21, 2020 11:28 AM
    I didn't have another opportunity to import the whitelist db. Maybe you can get an export of the current db, and use this information to create a config snippet to add the entries manually.
