My problem: I re-delpoyed an RAP "CanyonSSGate" (AP-274) after being off-line for several months. The AP is configured as an RMP. However, the flag only displays an M under Controller > Access Points - displays RM2 underWireless > AP Installation > Provisioning. When configured as an RAP, the AP does not show-up under monitor. However, it does list under Wireless > AP Installation > Provisioning.
The AP finds the controller - however, no SSID broadcsting. The RAP does not show Outer AP IP address.
Other RAPs in same Group have no problem.
The attached will display the above.
I contacted TAC: They are not that keen on RMP. I convinced the tech that RAP is most important - no RMP without RAP.
One note: The controller locks when creating a Technical Support file for the AP. System is HA - both controllers would lock when creating TS file on either controller.
Any help is appreciated. The AP is 40 miles away, and several meters up a utility pole. I hate to replace. What commands/files are available on the AP CLI via telnet?
TIA
Greg Crockett
