Ok, Here's the odd part. If I attempt to connect to the master virtual controller I get the basic error connecting error message. If attempt to connect to the 2cd access point in the cluster in Internet Explorer I get the SSL cert error and when I select continue it then times out after redirecting to the Master virtual controllers address.
At the site, it does work fine. I do remember there was a check box to allow access to the mgmt. UI from remote networks. I forget what exactly it said, it was on the older version of code for the IAP-105. I see now there's a management access on the firewall portion that by default is empty. Do you know if it allows all networks by default?
John Trumbell
Network Engineer
IT Infrastructure Services
519.759.4150 ext. 5556
519.750.0749 Fax
519-757-2672 Mobile
JTrumbell@brantford.ca[cid:
image001.png@01D0513F.DF81CE40]
This email and any files transmitted with it are confidential and may contain privileged information. Any rights to confidentiality and privilege have not been waived. You must not present this message to another party without the permission of the sender. If you are not the intended recipient you must not copy, distribute or use this email or the information contained in it for any purpose other than to notify us. If you have received this message in error, please notify the sender immediately, and delete this email from your system. We do not guarantee that this material is free from viruses or any other defects although due care has been taken to minimize the risk. Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of The Corporation of the City of Brantford.
