Scenario:
We are wanting to take a RAP205 and attach and S3500 to it for extended ports. My idea is for the users who connect to the S3500 would be authenticated against ClearPass (like they would be on the RAP205 wired port).
Problem:
It seems when I have the S3500 connected to the RAP, any devices connected to the S3500 are not able to see the RAP or controller. Initially I used a factory default S3500 config, but since have made a couple modifications. Either config, devices are not getting DHCP from the controller, not able to ping anything and on the controller I do not see the S3500 listed as a client in the client list on the controller. At this point I am not sure where to go.
Additional information, if I take a laptop and hard wire it into the wired port on the RAP (using the same port the S3500 would be plugged into), the laptop authenticates successfully against ClearPass as expected.
In summary, I am just needing some guidance/advice on how to setup an S3500 switch connecting to an RAP 205 and then have devices on the S3500 switch authenticate against ClearPass.
