Remove AP from Aruba Central 2.5
  • 1.  Remove AP from Aruba Central 2.5
    Posted Feb 14, 2020 05:46 PM
    Does anybody know if there is a procedure to manually remove a device from the Device inventory?
    Thanks in advance
  • 2.  RE: Remove AP from Aruba Central 2.5
    Posted Feb 14, 2020 05:51 PM
    as a Central use, you  cant delete an AP from Central. You can un-assign license to it from Central and this removes the AP from the management of Central and will be highlighted as red in the Central inventory.
  • 3.  RE: Remove AP from Aruba Central 2.5
    Posted Feb 14, 2020 05:54 PM
    Hi Ariya,
    But what if I want to add the device to another Aruba Central Account?
    Regards
  • 4.  RE: Remove AP from Aruba Central 2.5
    Posted Feb 14, 2020 06:09 PM
    There is no way to remove the device from 'Device Inventory'. If the device is unsubscribed and it is added to another Aruba Central account, the entry is removed from 'Device Inventory'.
  • 5.  RE: Remove AP from Aruba Central 2.5
    Posted Feb 15, 2020 01:39 AM
    yes just unsubscribe the device and then add it to another account.
    if that does not work, please get TAC involved.
