last person joined: 4 hours ago
Remove Aruba branded footer from Clearpass Guest Self Registration
  • 1.  Remove Aruba branded footer from Clearpass Guest Self Registration
    Posted Nov 26, 2014 09:56 AM
    I'm sure I've done this before but can't remember how.  My customer is using the "custom skin 1" skin with just a basic logo.  He wants to remove the "Copyright 2014 Aruba Networks" from the bottom of the self registration form (security reasons - doesn't want to advertise what platform they use)
    I've tried editing the footer of the registration page, etc, but that doesn't get rid of the aruba footer.
    Any ideas where I can find that?
  • 2.  RE: Remove Aruba branded footer from Clearpass Guest Self Registration
    Posted Nov 26, 2014 10:37 AM
    Go to Administration > Plugin Manager
    Then go to the Custom Skin and do the following
    Change the Page to Advance Settings
    Then you will see the option to edit the footer you can remove the content or change it to something of your preference
  • 3.  RE: Remove Aruba branded footer from Clearpass Guest Self Registration
    Posted Nov 26, 2014 10:58 AM
    Thanks!!! I knew it was something simple, just couldn't remember it for the life of me!
