Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
Remove Bricked AP from Instant setup. v. 8.10.0.2
  • 1.  Remove Bricked AP from Instant setup. v. 8.10.0.2
    Posted 7 days ago
    Hi.
    I have an Instant setup running around 60 AP's. 2 have been changed duo to malfunction and 1 have been moved to an other location.
    So 3 AP's is showing as down. But there is no way to remove them from web gui.
    Found the mac-adresses og the 3 bricked aps in the cli with "show allowed-aps" and cross refrenced it with the ap UP list.
    But cannot find any way to remove them,
    Anyone have any surgestions on how to?
    Kind regards.
  • 2.  RE: Remove Bricked AP from Instant setup. v. 8.10.0.2
    Posted 6 days ago
    https://www.arubanetworks.com/techdocs/Instant_83_WebHelp/Content/Instant_UG/CustomizeIAPParams/Removing_an__from_the_Ne.htm
    You can remove an Instant AP from the network by using the WebUI, only if the Auto-Join feature is disabled.
  • 3.  RE: Remove Bricked AP from Instant setup. v. 8.10.0.2
    Posted 6 days ago
    Thank you. That worked perfectly. :)
    Kind regards.
