remove client from blacklist
  • 1.  remove client from blacklist
    Posted Feb 07, 2017 02:51 AM
    Hi, everyone. I faced a little problem after update to ArubaOS 6.4.4.10 in 3000 series controller. Aruba is configured to send client to blacklist after 3 authentication failures. So, after the update I cannot remove client from blacklist by GUI (I can see and mark clients that I need in to unblock in blacklist, but buttons "remove from blacklist" and "Remove all from blacklist" doesn't work). I tried different web browsers , but result was the same. Also, I can easy remove clients from blacklist by CLI. So, does anyone could solve that problem with GUI?
  • 2.  RE: remove client from blacklist
    Posted Feb 07, 2017 06:07 AM
    Did you try clearing your browser cache?
    Do you see any javascript errors when you try to remove it?
  • 3.  RE: remove client from blacklist
    Posted Feb 07, 2017 06:40 AM
    Hi cjoseph, Yes, I cleared browser cache, but result was the same - client is still blacklisted. About javascript - there are no errors on the page. After pressing the button "remove client from blacklist" page just reloads with no errors (and show updated values of Remaining and Block Time).
  • 4.  RE: remove client from blacklist
    Posted Feb 07, 2017 06:50 AM
    You can type "show audit-trail" to see if the command is being executed:
    Feb  7 05:48:53  webui[3498]: USER:admin@192.168.1.236 COMMAND:<stm add-blacklist-client "d0:f2:fb:3a:2e:57" > -- command executed successfully
  • 5.  RE: remove client from blacklist
    Posted Feb 07, 2017 07:10 AM
    I've just checked "show audit-trail" and found that such command was not executed from GUI. It looks like buttons to remove clients from blacklist don't work from GUI)
  • 6.  RE: remove client from blacklist
    Posted Feb 07, 2017 07:20 AM
    You should upgrade to 6.4.4.11.  Release notes for 6.4.4.11:
  • 7.  RE: remove client from blacklist
    Posted Feb 07, 2017 08:12 AM
    Actually it's not that I was expected, but seems it's the only solution of this problem. Thank you.
