Network Management
Remove Down Devices for Airwave 8.0.3
  • 1.  Remove Down Devices for Airwave 8.0.3
    Posted Sep 10, 2014 02:17 PM
    I have Airwave 8.0.3 and have been adding Alcatel Lucent OS6850. My remote site's seem to have caused an issue with the down device list not showing any rows. Is there a way to remove the devices via command line or a database editor. Attached is a screenshot of the list so you can see what I am. Here is a copy of the system event log too:
    Attachment(s)
    txt
    EventLog.txt   9 KB 1 version
  • 2.  RE: Remove Down Devices for Airwave 8.0.3
    Posted Sep 14, 2014 09:31 AM
    There is a way. If you have not already, please contact support to ensure that you use the right command and if there is a bug, it can be reported and fixed.
  • 3.  RE: Remove Down Devices for Airwave 8.0.3
    Posted Sep 18, 2014 10:48 AM
    We suggest against direct database removal as it may leave some remnants in other tables.  It's best to do this operation from the GUI.  I suggest first upgrading to 8.0.4 (it's more stable).  Then go to an AP list view, select modify devices, bulk select the down devices and then delete.
