Comware
  • 1.  Remove port from default VLAN
    Posted Aug 29, 2016 06:53 AM
    Hi there,
    i have a Problem with VLAN-Config on a Switch 1950-48.
    I will seperate some Port from the default VLAN but in the WEB-GUI it is not possible or i can´t found the config option.
    1 have configured Port 1-4 as Untagged VLAN 4(192.168.34.0/24) and TAGGED VLAN 7(192.168.37.0/24)
    In untagged VLAN 4 is a DHCP-Server running, also in DEFAULT VLAN 1. if i connect to a untagged Port with vlan4, sometimes the DHCP-Server from VLAN 1 is answering that is one reason why i want to remove port 1-4 from default vlan(or switch to tagged), but i dont know how.
    Is there anybody who can give me an advice ?
    regards to the hpworld
    Thomas
    #VLAN
    #1950
  • 2.  RE: Remove port from default VLAN
    Posted Aug 29, 2016 08:16 PM
    On the DHCP Service page, under Advanced Configuration, you can disable DHCP Relay.
    If your DHCP server in VLAN1 is responding to DHCP requests in VLAN4, then,
    either,
    DHCP relay is enabled on VLAN4
    or,
    DHCP Server in VLAN1 is patched to a switchport that is untagged in VLAN1 and tagged in VLAN4
  • 3.  RE: Remove port from default VLAN
    Posted Aug 30, 2016 04:30 AM
    Halo Vince,
    thanks for your reply.
    The DHCP-Server of this device is disabled. Do you mean i have to enable it and configure as DHCP-Relay ?
    I would prefer to leave DHCP disabled and remove this Port from VLAN, if it is possible...
    Would remove from config-file work ?
        interface GigabitEthernet1/0/1
        port link-type hybrid
        port hybrid vlan 1 4 untagged (remove the 1,copy config to switch and reboot?)
  • 4.  RE: Remove port from default VLAN
    Posted Aug 30, 2016 07:57 PM
    I have seen that 3COM switches allow multiple untagged VLANs on the same port - this makes no sense to me, and any other vendor would tell you you can't do it.
    You should only ever have a maximum of 1 VLAN untagged on any switchport.
    I'd get rid of the "hybrid" setting - that could be the cause of the confusion. Change it to trunk.
    #hybrid
    #VLAN
    #H3C
