remove the "terms and conditions question " on an IAP Captiva Portal?
  • 1.  remove the "terms and conditions question " on an IAP Captiva Portal?
    Posted Aug 27, 2014 04:09 AM
    Is it possible to remove the Accept Window "terms and conditions" on an IAP Captiva Portal? Same like on the Controller “ show acceptable user policy page”
    Best Regards
  • 2.  RE: remove the "terms and conditions question " on an IAP Captiva Portal?
    Posted Sep 01, 2014 05:12 AM
    with the controller you can customize all you want, you also have the "Show the acceptable use policy page" option in the captive portal profile.
    for the IAP it doesn't appear possible. you could try to blank the terms and conditions field and see if it then dissapears.
    if not then you might want to raise an "idea" for that.
