Remove Virtual Cluster from Airwave
  • 1.  Remove Virtual Cluster from Airwave
    Posted Nov 17, 2016 09:45 AM
    Here is my setup.  Dell branded airwave (Dell PowerConnect) version 8.2.2, and all of my VC are being configured via Airwave.  I have recently combined two VCs into a single one cannot figure out how to delete/remove the old now outdated VC.  Since everything is managed by Airwave even when I go into manage for this device I do not see a delete button.  I have attached a picture of what I am trying to remove, before I call support I figured I would ask see if anyone knows how to remove this.  Let me know if any additional info is needed on this.
  • 2.  RE: Remove Virtual Cluster from Airwave
    Posted Nov 17, 2016 11:14 AM
    Can you go to APs/Devices and click on the device. Then select manage. Then delete.
    Cheers
    James
  • 3.  RE: Remove Virtual Cluster from Airwave
    Posted Nov 17, 2016 01:28 PM
    That is what I thought I could do, but when I go to manage it just takes me to the VC list.  Maybe I am missing something?
    --Daniel
  • 4.  RE: Remove Virtual Cluster from Airwave
    Posted Nov 17, 2016 10:44 PM
    SSH directly into that AP and do this:
    config t
    no virtual-controller-key
    commit apply
    Reboot and see if that works..
