Hi Matt,
Yes to remove a port from a VLAN (or to remove a VLAN from a port, it's the same...just the PoV changes and the commands consequently change too since the focus changes with the PoV) you can use two different approaches with the same results.
I encourage you to first check the VLAN membership of the given port (and
repeat the very same command after the re-configuration to see result):
show vlan ports ethernet 2/38 detail
Method 1 (remove - add is the same just pay attention to remove the "no" at beginning - the VLAN from a port from inside the VLAN x configuration context or from outside that context):
vlan 1
no untagged ethernet interface 2/38
write memory
exit
from the general configuration context:
no vlan 2099 untagged ethernet 2/38
Method 2 (remove - add is the same - the port from the VLAN from the interface context or outside that context):
interface ethernet 2/38
no untagged vlan 1
write memory
exit
no interface ethernet 2/38 untagged vlan 1
Davide Poletto
Original Message:
Sent: Sep 16, 2021 10:53 PM
Subject: Remove vlan from port
Our switches were configured by someone else and with everything going I haven't had the chance to work and learn the Aruba switches the way I wanted to. Now, I need to go in to a couple ports and remove a vlan from them and I'm not real sure how to. I believe I would do the following, but just want to make sure I have it correct. So say port 2/38 is tagged on vlan 10 and untagged on vlan 1. I would switch to config mode then enter the commands below to untag port 2/38 in vlan 1
vlan 1
untag interface 2/38
write mem
Thank you for your help
Matt Gross
