Wired Intelligent Edge
Remove Vlan From Switches
Jump to Best Answer
  • 1.  Remove Vlan From Switches
    Posted Jun 27, 2022 10:54 PM
    I've been getting more comfortable with Aruba switches. I'm at a point now where I need to remove some vlans from the switches. If I wanted to remove vlan 10 completely from the switch, would the command from the config prompt be, no vlan 10 ? Thank you for your help.
  • 2.  RE: Remove Vlan From Switches
    Posted Jun 27, 2022 10:57 PM
    Sorry, they are 2930m switches.
  • 3.  RE: Remove Vlan From Switches
    MVP GURU
    Posted Jun 28, 2022 08:01 AM
    CLI -> config -> no vlan 10 -> write memory <- this will remove del VLAN id 10 (ports untagged only - or tagged only - on that very VLAN id will revert to be untagged on default VLAN 1 IIRC).
  • 4.  RE: Remove Vlan From Switches
    Posted Jun 28, 2022 08:43 AM
    Thank you. Appreciate it!
