Wired Intelligent Edge
last person joined: 11 hours ago
Removing a Member from a stack
  • 1.  Removing a Member from a stack
    Posted Mar 08, 2023 03:06 AM
    Good morning, I just removed a member from a stack with Aruba 2930F. I have used the "vsf member 5 remove" command and moved the DAC cables. But in order for it to recognize the new links, I wanted to reboot the previous member with the "vsf member 4 reboot" command, but there is no such option. I have had to do it physically and everything has worked. My question is, is it necessary to reset this member for it to recognize the links? And if so, is there any other command to do it? Thank you so much.
