Network Management
  • 1.  Removing aaa authentication ssh command from cli
    Posted Jun 14, 2024 08:24 AM
    I'm trying to remove the config in red box from Aruba, but I'm not able to.
    I tried no aaa authentication ssh enable radius server-group mgmt local but that's not a valid syntax for the cli.
  • 2.  RE: Removing aaa authentication ssh command from cli
    Posted Jun 14, 2024 09:59 AM
    If that is for ArubaOS Switch (example 2540/2930/3810/5400R), then you would enter the default for the command to get it removed.
    Can you try:
    aaa authentication ssh enable local
    If it's not an ArubaOS Switch, it may help to mention the model number and firmware version.
  • 3.  RE: Removing aaa authentication ssh command from cli
    Posted Jun 14, 2024 10:08 AM
    @Herman Robers, thank you so much, that's what I was looking for.
  • 4.  RE: Removing aaa authentication ssh command from cli
    Posted Jun 14, 2024 10:25 AM
    Weirdly, I'm able to use 'no' to take out other commands above it, but not that one.
    That's what got me stuck.
