You can select template and skin under Receipts -> E-mail Receipts:![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/ffb94fbedd454332aef095840d2dc8d0.png)
So you can select another skin that has your own logo, or modify the template (under Receipts Templates). For some modifications, understanding of HTML and CSS may be useful.
Original Message:
Sent: Feb 29, 2024 10:20 PM
Subject: Removing "Aruba Networks" banner from ClearPass receipt email?
Were you able to remove the huge Aruba Logo in the sponsor confirmation email? I am also looking for ways to customize the email receipt but couldn't figure where to remove the aruba logo in the email. TIA
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/3f7d3a43e5e548d681670641c72a0533.png)
Original Message:
Sent: Feb 19, 2021 03:49 PM
Thanks again, I found an option I had previously missed.
Jeff
Original Message:
Sent: Feb 19, 2021 02:17 PM
Other receipt templates for sponsor confirmation email i.e here
![Interfaz de usuario gráfica, Aplicación, Teams Descripción generada automáticamente](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/1cf113c4edcb45208e9d4ea073ac7a38.png)
Jorge Calvi
Original Message:
Sent: 2/19/2021 2:13:00 PM
Subject: RE: Removing "Aruba Networks" banner from ClearPass receipt email?
Hello, this is part of the skin plugin you are using, and you must go here in order to modify those templates
![Interfaz de usuario gráfica, Texto, Aplicación Descripción generada automáticamente](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/ead7d12b408049a5815974843143b984.png)
Hope it helps
Regards
Jorge Calvi
Original Message:
Sent: 2/19/2021 12:59:00 PM
So I think the subject is pretty clear cut, and I'm sure Aruba makes removing this non obvious for obvious reasons, but my manager would like to see it done if possible.
Is there a way to remove the "Aruba Networks" banner from the guest self registration receipts? I've done alot of reading in here, but most cases are about re skinning the Guest portal, I've deleted the headers and footers from the templates and Email receipts, and I figure then logo gets applied further downstream.
I'm sure someone has removed this, let me know if anymore information is needed.
Thanks for the help!
