Steps to remove AP from Central
- Detach Subscription: you know it :)
- Remove Assignment: remove from the existing Aruba Central instance.
- Archive: remove from the Green Lake inventory/Activate
Harendra
ACEX165
Original Message:
Sent: Aug 15, 2024 12:41 PM
Subject: Removing completely a AP from aruba central
i understand that archive is used for example if I'm not using the AP right now i will put it on archive just to have it organized and it will move it to a archive tab.
But i have no idea what the remove assignment does
Do i have to call the tac to remove completely the AP if I'm not using any more because it does not work and we have to replace it?
Original Message:
Sent: Aug 15, 2024 12:36 PM
Hello guys i have a AP that i want to completely remove from the aruba central because the AP we have to change it and it will no longer be on Aruba central
i already unsubcribed
I'm not sure if i just should archive it and that's it or remote assignment
Let me know guys
