Hi everyone.
I'm using the default dhcp from the IAPs. Is there a way to disable NAT so my firewall sees user's ip adress and not IAP's address incoming?
Thanks.
In the SSID configuration, the VLAN needs to be network assigned instead of "Virtual Controller Assigned". The VLAN specified would have to be defined on the trunk between your IAPs and your switch, or you can just make it VLAN 1 to make it on the management VLAN of the IAP.
http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/WLAN_SSID_conf/ConfiguringVLANSettings.htm?Highlight=virtual controller assigned
Ok, that's what I feared.
Thanks for your quick answer.
