Removing unlicensed devices from Aruba Central
  • 1.  Removing unlicensed devices from Aruba Central
    Posted Oct 25, 2016 02:41 PM
    I have a few unlicensed devices listed under Device Provisioning in Central that are not owned by us any longer due to selling part of our businesses.
    Is there any way to remove them?
    Russell
    Austin, TX
  • 2.  RE: Removing unlicensed devices from Aruba Central
    Posted Oct 25, 2016 04:04 PM
    Under Maintenance > Device Provisioning > Manage Licenses and Search for the device(s) in question and unassign the license
  • 3.  RE: Removing unlicensed devices from Aruba Central
    Posted Oct 25, 2016 05:02 PM
    I already mentioned they are unlicensed, I knew how to do that.
    I want to now get the UNLICENSED devices to be no longer visible in the list.
    RH
  • 4.  RE: Removing unlicensed devices from Aruba Central
    Posted Oct 25, 2016 05:31 PM
    Sorry misread your post
    You will need to remove those devices from Activate and then resync
  • 5.  RE: Removing unlicensed devices from Aruba Central
    Posted Oct 25, 2016 07:29 PM
    Thanks Victor.
    I was not familiar with Activate before today. I registered and now have access. However, it doesn't look like I can do much in Activate other than move devices around 'folders'. I do not see any way to 'remove' a device from Activate.
    I'll search the forums to see what I can find.
    RH
  • 6.  RE: Removing unlicensed devices from Aruba Central
    Posted Nov 16, 2016 01:34 PM
    Where the heck is "Activate?" Not that it looks like it's going to help anyway. I can not figure out how to delete an unmanaged, unlicensed device. I swear this Aruba Central interface is an absolute pain to navigate. Not intuitive by any means!
