Rename ap
  • 1.  Rename ap
    Posted Aug 19, 2013 08:22 AM
    I feel pretty dumb at the moment, but i cant seem to get a few APs renamed properly.
    The command i use is;
    ap-rename wired-mac 00:0b:86:69:54:86 test
    The AP reboots and comes back with 00:0b:86:69:54:86 instead of test. Logs show the command is executed succesfully.
    Help :)
  • 2.  RE: Rename ap
    Posted Aug 19, 2013 08:50 AM
    Try going into the GUI and reprovisioning the APs you want to change.  At the bottom of this page is the AP name field.
  • 3.  RE: Rename ap
    Posted Aug 19, 2013 08:54 AM
    Renaming the ap-name with the help of wired-mac should be fine. If i am wrong you have the got the AP`s mac address from the command "show ap database long" and not the BSSID.
    Can we try ap-rename "ap-name" instead of  wired-mac ?  Thanks!
  • 4.  RE: Rename ap
    Posted Aug 20, 2013 03:27 AM
    Tried via GUI and using ap-name instead of wired-mac but no luck :)
