Rename VAP/SSID/AAA Profiles
  • 1.  Rename VAP/SSID/AAA Profiles
    Posted Jan 23, 2018 06:08 AM
    I would like to rename some of the various profiles we have configured (VAP/SSID/AAA etc.). I can see no way of doing this within the web interface, on to CLI however I can see there is a 'rename' command but it offer no contextual menu on how it can be used. I have tried obvious commands such as:
    '(Aruba-7205-1) (Virtual AP profile "VAP NAME-vap_prof") #rename 'NEW VAP NAME-vap_prof' '
    but this does not work.
    Can this be done or is it a case of cloning all the profiles I want to rename and repointing all the references to the new profiles?
    Thanks.
  • 2.  RE: Rename VAP/SSID/AAA Profiles
    Posted Jan 23, 2018 06:16 AM
    rename is for renaming files in the flash (e.g. see them with "dir").
    I would recommend you make use of the "clone" command, something like this - being mindful of the ordering. Depending how long your list is, this should be pretty quick relative to webui means
    conf t
      wlan ssid-profile new_ssid_profile
        clone old_ssid_profile
      aaa profile new_aaa_profile
        clone old_aaa_profile
      wlan virtual-ap new_vap_profile
         clone old_vap_profile
         aaa-profile new_aaa_profile
    exit
  • 3.  RE: Rename VAP/SSID/AAA Profiles
    MVP
    Posted Jan 23, 2018 07:36 AM
    I myself use dugem2016's solution for this as well, but if you want to use the GUI, via 'All Profiles' look up your profile and select it. In the top right corner there should be a 'save as' button which can be used to clone the current profiles.
    dugem, you probably know this, but you can combine the creation of the new profile and the cloning into a single command:
    wlan aaa profiles new-profile clone old-profile
    wlan ssid-profile new-profile clone old-profile
    wlan virtual-ap new-profile clone old-profile
  • 4.  RE: Rename VAP/SSID/AAA Profiles
    Posted Jan 23, 2018 08:29 PM
    yep, valid short cut, just dont forget to go back into wlan virtual-ap and fixup the aaa and ssid profile :)
  • 5.  RE: Rename VAP/SSID/AAA Profiles
    Posted Jan 24, 2018 03:45 AM
    Thanks both for your help.
