Renaming or Removing Group in Central
  • 1.  Renaming or Removing Group in Central
    Posted Aug 12, 2014 10:17 PM
    Hello All, anyone can advise how to go about renaming or removing a group in central. When I try to deletre the group it say it is a working  group and cannot be deleted. How do I make it a non working group? FYI there are zero APs on the group at this point.
  • 2.  RE: Renaming or Removing Group in Central
    Posted Aug 12, 2014 10:26 PM
    Make sure you have a different group selected before you click the “Manage” button.
  • 3.  RE: Renaming or Removing Group in Central
    Posted Aug 13, 2014 01:58 AM
    Thanks Tim for the tips.
  • 4.  RE: Renaming or Removing Group in Central
    Posted Jan 08, 2015 10:26 PM
    I was getting the same error, so I did this, but now I get the following -
    The 4 APs that were in this group have been assigned to a different group and unassigned from Cloud management entirely.  How do I delete the group?
  • 5.  RE: Renaming or Removing Group in Central
    Posted Aug 12, 2014 11:40 PM
    In addition to Tim's answer to deleting a group, you cannot rename a group.    You can clone a group with a new name; then move the virtual controller to the new group.
  • 6.  RE: Renaming or Removing Group in Central
    Posted Aug 13, 2014 02:00 AM
    Hi Clembo, thanks but it will be good if we can rename at the same time after we clone if we can change the SSID etc will be a key advantage as of now we have to create almost everything from scratch. But thanks for the infromation.
