Is it possible to rename a exisiting SSID in Instant Config?
I dont think you can rename it, however if you copy the lines of config into notepad, make the change and then paste them into the CLI (under configure terminal) this will add in a new one and you can then delete the old one.
you can not rename an ssid, not on airwave and not on the vc.
delete the ssid and make it new, it´s not so difficult to configure a ssid on instant vc.
If you found my post helpful, please give kudos
