Wired Intelligent Edge
Renumber SW ID
  • 1.  Renumber SW ID
    Posted Sep 06, 2020 10:05 AM
    Hello everybody,
    I trying to change the sw id .
    How i do it in ArobaOS-CX?
    i trying the "set" command.
    Someone can help me to renumber the SW slot id.
  • 2.  RE: Renumber SW ID
    Posted Sep 08, 2020 02:26 PM
    Greetings!
    We could use a bit of clarification — what are you referring to when you say "SW ID"?
    If you mean the VSF member ID, you would use 'vsf renumber-to' from the configuration context. For the switch hostname, use the 'hostname' command from the configuration context.
    If neither of these is correct, please let us know what you're trying to change.
  • 3.  RE: Renumber SW ID
    Posted Sep 09, 2020 09:52 AM
    I have two switches,
    When I put the command: show lacp aggregates
    I get:
    Aggregate name: lag100 (multi-chassis)
    Interfaces: 1/1/52
    Peer interfaces: 1/1/52
    Heartbeat rate: Slow
    Hash: l3-src-dst
    Aggregate mode: Active
    so...
    I have a 1 lag with multi-chassis
    I want to change the secound switch number.
    I want to get:
    Interfaces: 1/1/52
    Peer interfaces: 2/1/52
    but dont do vsf or somthing. stay with the multi-chassis
  • 4.  RE: Renumber SW ID
    Posted Sep 09, 2020 10:28 AM
    What is your switch type? do you nee MC-LAG or normal LACP?
    when using vsf you get slot numbers like 1/1/52 and 2/1/52, you don't need MC-LAG when using VSF, just us normal LAG
    when using MC-LAG you are making lacp coming from switches ports 1/1/52 (SW1) and 1/1/52 (SW2). In this case the lacp stretches accros switches.
  • 5.  RE: Renumber SW ID
    Posted Sep 09, 2020 10:57 AM
    First of all thank you.
    My switch type is: 8320
    I need MC-LAG
    I know when i make vsf I get slot numbers like 1/1/52 and 2/1/52,
    but im using MC-LAG so i want to renumber SW2 slot to 2
  • 6.  RE: Renumber SW ID
    Posted Sep 09, 2020 02:43 PM
    If you are configuring MCLAGs using VSX, it is expected that both switches have a switch ID of 1, because they are both operating in standalone mode (with VSX providing MCLAG functionality and state synchronization across the ISL). There is no need to change the switch ID number, nor is there any functionality to do so with the 8320 as it does not support VSF (stacking), which is the only feature in the AOS-CX product line that requires renumbering the switch ID number.
