Network Management
Replace Degraded Drives in AirWave Appliance
  • 1.  Replace Degraded Drives in AirWave Appliance
    MVP
    Posted Jan 29, 2020 10:10 AM
    We have a physical airwave appliance (HP Proliant DL360p G8) and all but 1 of the physical drives are running in a degraded state. We have spare drives in our office and would like to swap out the bad drives for new ones, but don't know the process, or even if this is possible/recommended. If we can do this, is there a process to follow?
    Thanks.
  • 2.  RE: Replace Degraded Drives in AirWave Appliance
    Posted Jan 29, 2020 12:05 PM
    Check this below link, safer side take Airwave backup before you try hot swap, it should work.
    https://support.hpe.com/hpesc/public/docDisplay?docId=c03438790#N102EA
  • 3.  RE: Replace Degraded Drives in AirWave Appliance
    MVP
    Posted Jan 29, 2020 12:15 PM
    Thanks for providing that information. We will give it a try and see how it goes. We've had a lot of performance issues with the large amount of bad drives, so hopeful this helps.
