Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
  • 1.  Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:25 PM
    I had to restore the config via memory because the other box got fried.  No 1 of 2 SSID's aren't showing.  I have checked the virtual AP and the SSID itself and they are all enabled.  Whats strange is the other SSID applied to this AP group is showing.
    Can someone help me out?
  • 2.  RE: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:26 PM
    Can you do a show profile-errors
    And also do show ap essid
  • 3.  RE: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:32 PM
    Yeah I don't see the other SSID there, only the one.
    (Aruba650) #show profile-errors
    Invalid Profiles
    Profile Error
    aaa authentication via auth-profile "default"
    (Aruba650) #show ap essid
    ESSID Summary
    ESSID APs Clients VLAN(s) Encryption
    CompanyGuest 6 3 2 Open
    Num ESSID:1
    (Aruba650) #
    But if I show that wlan ssid-profile its there:
    (Aruba650) # show wlan ssid-profile ComapnyN-ssid_prof
    SSID Profile "InfobloxN-ssid_prof"
    Parameter Value
    SSID enable Enabled
    ESSID CompanyN
    Encryption wpa2-aes
    DTIM Interval 1 beacon periods
    If I look at that specific AP group it only shows the SSID not showing?
    (Aruba650) #show ap config ap-group Burnaby
    SSID enable Enabled Enabled wlan ssid-profile "CompanyN-ssid_prof"
    ESSID InfobloxN InfobloxN wlan ssid-profile "CompanyN-ssid_prof"
  • 4.  RE: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:34 PM
    Do you have a VLAN assigned to the VAP that exists in the controller ?
  • 5.  RE: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:36 PM
    You mean under Wireless > AP Configuration > Burnaby > Wireless LAN > VAP > ComapnyN-vap_prof?  Then yes I do, its the same vlan as the controller sits (vlan1).
  • 6.  RE: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:40 PM
    Is the VAP enabled too ?
  • 7.  RE: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:41 PM
    Yes.    If it wasn't why would the other SSID be showing?  It is part of the same VAP.
  • 8.  RE: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:45 PM
    Can you please share the config
    Also have you tried using the same VLAN as the one that is working ?
    I noticed that the SSID is a WPA2/AES make sure the the AAA profile has been assigned correctly under the VAP
  • 9.  RE: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:46 PM
    Victor
    I fixed it, that SSID was set to bridge instead of tunnel.  Once I changed it to tunnel it started broadcasting.
    Thanks for your help.
  • 10.  RE: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
    Posted Jul 10, 2013 03:50 PM
    Nice!!!
