Comware
last person joined: 4 hours ago
Replacement of HPE 5900 AF switches
  • 1.  Replacement of HPE 5900 AF switches
    Posted Feb 27, 2022 08:22 AM
    We have four HPE 5900 AF switches that act as our core routers. We think it may be time to have them replaced. They are going on 7 years old. Network design is fairly straigtforward with two of the switches in an IRF stack. Can someone make a recommendation for replacement of these switches? They all use primarily single mode fiber sfps with a mix of multimode and copper ethernet sfps mixed in. I just need a direction to go in. We want to stay with HPE/Aruba. It doesnt have to be comware for an os but we are very comfortable with it. Obviously a product/line that is not close to be EOL'ed.
    Eric Hutchinson
  • 2.  RE: Replacement of HPE 5900 AF switches
    Posted Feb 28, 2022 03:08 AM
    Hello Eric,
    There are a nuber of switches FlexNetwork and FlexFabric which are availabble with comware. You may check the 5944 which is new model. On the following link you may check the current line of comware switches and find suitable switch for your needs. It is best to check with your sales account manager or our partners for more details:
    5944:
    https://buy.hpe.com/us/en/networking/switches/fixed-port-l3-managed-ethernet-switches/5900-switch-products/hpe-flexfabric-5944-switch-series/hpe-flexfabric-5944-48xgt-6qs28-switch/p/JL836A
    Other comware switches:
    https://buy.hpe.com/us/en/networking/switches/c/4172267?q=%3Arelevance%3Afacet_productline%3AFlexFabric%3Afacet_productline%3AFlexNetwork&text=&textSearch=&pageSize=100
    Hope this helps!
    -Alex-
  • 3.  RE: Replacement of HPE 5900 AF switches
    Posted Feb 28, 2022 03:20 AM
    Hi Eric.
    As Alex pointed out, there are number of current comware switches available.
    5945 is a great switch and you can tailor it's configuration to your needs. You have fixed and modular variant. Modular variants have 2 or 4 slots.
    5980 is also suitable model you could use.
    If you go with ArubaOS-CX switches, you could go with 8360 or 8325.
    Best, Gorazd
    Gorazd Kikelj
