Replacing a hot swappable drive in a Clearpass C3000 appliance.
  • 1.  Replacing a hot swappable drive in a Clearpass C3000 appliance.
    Posted Sep 07, 2022 12:30 PM
    I have a Clearpass C3000 Appliance that needs to have one of the drives replaced. The C3000 is a HP Proliant server, not sure of the model.
    This may be a dumb question but given that the replacement drive is exactly the same spec as the failing one this should simply be a matter of pulling out the bad drive and sliding the replacement in correct?
    The drives are hot swappable so I assume that the new drive will automatically get rebuilt after it is installed.
    Am I correct in this assumption?
    Thanks in advance.
  • 2.  RE: Replacing a hot swappable drive in a Clearpass C3000 appliance.
    MVP GURU
    Posted Sep 07, 2022 01:47 PM
    Yes you should be able to pull out the old, and plug the new one in. Always create a backup of the server before replacing the drive though.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Replacing a hot swappable drive in a Clearpass C3000 appliance.
    Posted Sep 08, 2022 07:44 AM
    Thank You Dustin Burns.
    That was my thought but it's always worth a second opinion.
    Senior Network Analyst
    Ottawa Carleton District School Board
    Ottawa ON
    Canada
