Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
Replacing a VSX member
  • 1.  Replacing a VSX member
    Posted Dec 28, 2022 05:34 PM
    I just wanted to ensure everyone is aware of this updated procedure which have been asked quite often.
    When replacing a VSX switch member that is configured and managed through Aruba Central, ensure that the new replacement switch is assigned to the same group as the old switch. If the assigned group is the template group, ensure that the variables for the new replacement switch are same as the old switch. In the case of the UI group, if the VSX switch is configured using MultiEdit, you need to copy the original configuration from the MultiEdit configuration editor and paste it to the new replacement switch after moving it into the group.
    https://www.arubanetworks.com/techdocs/central/latest/content/nms/aos-cx/get-started/quick-start-switch-cx.htm
