Hi guys, yet to open it up, but the noisy fan in the A620 is causing complaints! I dont think its faulty, the speed of the fan seems to vary. Anyone know the size so I can replace it? Is there any software control of the RPM?
James
There is no software control of the RPM. If it is still under support, you should get it replaced. If it is not under support, you of course are taking chances doing whatever repairs you choose to do....
